Go Back   Caswell Inc. Metal Finishing Forums > Caswell Please Sell This...
Connect with Facebook
Caswell Please Sell This... Post Your Product Requests Here
Old 04-03-2009, 09:37 AM
woodjames's Avatar
woodjames will become famous soon enoughwoodjames will become famous soon enough
Default Tix Solder
4300 psi, melts and 275 degrees. Comes as 3" sticks, uses a flux that washes off with water.
James Bateman
Old 04-12-2009, 10:18 AM
lcaswell's Avatar
Caswell Inc President
Default Re: Tix Solder
What are you using it for?
Lance Caswell
Have A Web Site?
Old 04-12-2009, 04:49 PM
woodjames's Avatar
Repair work, mainly on aluminum. I can heat the heck out of a really thin coat of copper of aluminum, and use regular (50/50, plum loy) solder. However, a thick copper coat can blister if it gets too hot (even worse with die-cast zinc), thermal expansion issues. So if I notice a repair to be made after a thicker coat of copper (like a really deep pit in cast aluminum), I break out the Tix. It sands really easy, and the low temp makes repairs quick. Everything else gets the piece really hot, with 275 you can heat just a small area of aluminum, and literally hold the other end in your hand (6" circle for example). The next time I'm up, I can bring you a couple sticks, if you'd like to see it/try it.
James Bateman
Fastgold over solder jump Electroplating Questions 1 03-13-2005 05:53 PM
Solder-It Pot Metal Repair BryanD Plating Pot Metal 2 08-05-2004 11:59 PM
anodizing solder aluminum buckeyevs Anodizing Questions 3 02-27-2004 06:20 PM
Aluminum Solder Paste trw Other Metal Finishing Questions 2 03-25-2003 09:55 AM
Solder-NOT !? johnshenry Other Metal Finishing Questions 5 09-13-2002 03:54 PM
