Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Copy Chrome Kit Customers Only
Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit.
Old 06-28-2005, 03:12 PM
copierfixer
Default copychrome over silvaspray
I have a dash bezel that has round gauge border rings that i would like to rechrome. the part cannot be dipped easily, as it is pretty large, and the gauge border rings are separated from each other. Would the brush-type plug & plate copychrome work over the silvaspray? tTese border rings are only about 1/16" wide by 4" in diameter.. any other ideas? Thanks in advance.
paul
Old 08-24-2005, 03:58 PM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: copychrome over silvaspray
paul
Some plastic automotive pieces are actually molded with an underlying nickel surface
some are not the ones that are, are conductive like plastic car emblems you have seen the gold plated right if it is conductive you will not need silva spray . If they are not conductive you will .
First you will have to spray on a very light coat of silva spary then copper strike then acid copper
to build up the surface because silva spray has small particles of silver in it acid copper will bring your piece to a smooth finish then nickel then chrome
Jim
Old 04-10-2006, 12:55 AM
revving is on a distinguished road
Default Re: copychrome over silvaspray, very newby
Same car dash bezel rechroming problem.
I have a simple copychroming kit, some copper and nickel solution. I have some silverspray, I have tried several small pieces of plastic with no success.
I have a home made setup (voltage adjustable supply, using a piece of stainless stell as a anode, everything).
I can succesfuly a small plate a pieces of metal with copper, copy chrome, black chrome or nickel without problem using a wand or dipping with ajusting the electrical output at 4.5-6 volts. But just cant get result with silverspray on plastic. It just turn out "dirty" without any shine, even lightly buffed, seems like plating doesnt stick on at all
What is copper strike and acid copper does temperature of solution has to be higher than room temp? specific amperage or that depends on the amount of solution used in dipping??
is it the copper solution I have OK, then nickel, then chrome?
Is it possible to do this with a simple kit?
thanks for the help
Old 04-10-2006, 08:35 AM
jimcarry's Avatar
Well once you have a nice coat of silva spray you must use acid copper temp should be around 110 but follow the directions in the manual the acid copper should allow you to get the surface you want to be able to plate the copy chrome with out the nickle. Your amps depend on the surfface area of the part you are plating not the amount of solution
Jim Eaton
Old 04-10-2006, 07:04 PM
Thanks for replying with info
last night. I was actually able to plate some small plastic part with nickel and then copy chrome. Doesnt look too nice as the silvaspray has a tendancy to peel off.
I just have to get better at it and get some experience.
The copper solution that I have is probably not Acid copper. I cant find anything on Caswell or other site about that acid copper. Is it used with the same electroplating principle? Is it called something else?
thanks again
JF
Old 04-11-2006, 08:30 AM
jimcarry's Avatar
http://www.caswellplating.com/kits/copper.htm
here is a link to the copper kit you are looking for
Just a very thin coat of silva spray shoud reduce pealing
Jim Eaton
SILVASPRAY.....PROBLEM WITH BLISTERING! mdarr Electroplating Questions 2 03-28-2004 10:42 PM
Silvaspray Update Fireblade Powder Coating Questions 5 01-13-2004 02:26 PM
Silvaspray on a primered surface mdarr Electroplating Questions 0 10-23-2003 05:36 PM
the new silvaspray. adambond Electroplating Questions 4 07-15-2003 06:33 PM
Can Silvaspray be triple-chrome plated? thaugen Electroplating Questions 1 02-28-2003 11:07 PM
