Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Copy Chrome Kit Customers Only
Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit.
Old 07-18-2005, 08:06 PM
mcaswell's Avatar
Caswell Inc Founder
Default DULL GREY COATING
Is anyone else experiencing a dull grey coating on their work? It seems this coating buffs off quite easily.
Anyone found a way of stopping this happening?
Have A Web Site?
Old 08-18-2005, 01:30 PM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: DULL GREY COATING
I have found that using exact measurements when placing your item into the tank absolutely no closer then 3 inches from the anodes. In all cases I use a higher temp between 95 and 110
I also have found that a combination of higher temp and lower amps works very well
Old 11-25-2005, 04:23 PM
-ego- is on a distinguished road
I have not figured out how to get rid of the dark dull grey spots. I actaully just set aside my copy chrome tank for a month and now I'm going to give it a try again. I have buffed and it does seem to come off quite easily but I still don't think the color after its buffed matches the blue chrome look. Looks more like nickel. I am going to do what Jim said and raise the bath temp.
A question for Jim... it sounds like you have plated a succesful copy chrome part. And if so, does the color match chrome exactly?
Old 11-26-2005, 01:58 PM
jimcarry's Avatar
Ego
When I plate with copy chrome .
After the part is cleaned and prepd .I wire the part up just as it will be plated then I soak in de greaser sometimes for 30 minn but not absolutely
necessary I use a rag and clean the parts while there in the de greaser . Then rinse in hot distilled water I keep the part as hot as possible so not to change the temp of my solution to much ( we are talking about a three gallon tank . While my parts are soaking I heat my chrome tank to 110 this will allow for cool down . After tank is heated I place my pump in supplied by Caswells then my anodes. Afterwards I take my part already on the hanger set into the center of tank I then
adjust my anodes within three inches of the part then I apply the pre measured amps .
The formula I use is 1 amp per 32 sq” .
Make sure your cleaning and storing your anodes properly .
And brighteners do get used up as you plate. If you are plating all day you must keep an eye on the temp of your chemicals give me a shout if you have any more questions
here check out my photos http://forum.caswellplating.com/phot...0&ppuser=17870
Jim Eaton
Old 12-28-2005, 06:56 AM
Soundsurgeon is on a distinguished road
I have exactly the same. I am investigating this - watch this space( hopefully!). I have plated 1 small brass part as an experiment with success first time. I then drained the tank etc, stored the solution for a few weeks. Started plating again - grey deposit.
1, Dropped temperature 10 F - no change.
2, Decreased plating current density to 50% - no change.
Next I will try:
Check solution concentration.
Check PH.
Check for Zinc Ions in the solution (I have a chemist friend who would love to mess with this).
Dummy plate to remove contaminants - problem with this is I cannot download anything other than the area calculator from the download site..
Bye fo now.
Old 12-29-2005, 11:01 AM
jimcarry's Avatar
Next I will try:
Check PH.
Bye fo now.
Question
What size kit are you using
Jim Eaton
Old 01-22-2006, 07:27 PM
RickB1B
I am having the exact same problem. Dull grey coating that, when buffed, looks good. If anyone figure this out please post the solution.
BTW I am plating at 70 degrees and 1 amp per 15 square inches. Next Time I'll try heating to 110 and lower amps.
  #8 (permalink)
Old 01-23-2006, 08:34 AM
jimcarry's Avatar
Here are my thoughts.
Gray coatings are caused by
not enough brightener in your solution in the smaller kits the brightener to solution ratio
seems to be correct as you get into the larger kits I be leave the ratio changes and more brighteners need to added . Another factor is the temp of the copy chrome if you are using the 70 degree temp this is just not enough please bring the temp to 110 and start there we must remember that as we plate the temp will change keep a close eye on this as all shops and areas are different
for instance my solution drops at a rate of 3 degrees per hours in an insulated tank during the winter months in Arkansas. And at 1 degree per hour in the summer months same tank .
It is also important that we all remember that as we plate we are depleting the brighteners
and we must keep an eye on this and replace them as needed KEEP some in your shop .
If your plate is burning the most common problem I have found by talking to a lot of you on the phone is the temp and agitation a few bubbles in the tank are not enough the agitation effect your are looking for is like a boiling pot of water
Jim Eaton
Removal of unknown coating on aluminum rclint Metal Polishing Questions 6 08-25-2005 12:04 AM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 11:49 AM
Does a coating exist that can be bent slightly? Augest Powder Coating Questions 1 09-22-2003 01:34 PM
grey color problem johnlindahl Electroplating Questions 1 10-29-2002 03:34 PM
Dull zinc wanted... fargap Electroplating Questions 1 09-28-2002 12:47 PM
