Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Copy Chrome Kit Customers Only
Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit.
Old 01-14-2006, 04:02 PM
93FATBOY is on a distinguished road
Question power source
I want to set up the battery charger to battery setup. Im not an electrical engineer and the local Radio Shack is of no help. Im going with this set up because I already have the charger ( has 2 , 6 and 10 amp modes)and battery ( motorcycle battery ) just not sure how the rest of the set up should go and what components I need.The manual is helpful yes but I have no clue what a rheostat does or what type of rheostat I need .From what common sense is telling me is that I need to be able to control the amps...Im trying to keep the setup as simple as possible for now.Any help would be appreciated .
Old 05-14-2006, 02:14 AM
pjstein
Default Re: power source
You really need to look at the manual. The amperage depends on the surface area you want to plate and what you are using to plate with. I've been doing copycad for awhile now and I use a 6 volt battery and control the amperage with small light bulbs. Copycad takes very little power, about .025 amps per square inch so the 6 volt system works well. I just add or subtract light bulbs to increase or decrease my amperage. As far as the battery charger goes, I have one hooked up to the battery and charging and still connect the battery to the plating tank. I bought a really cheap amp meter to check if the setup was really working and it does. If you are going to do chrome you are going to need 1 amp per 1 square inch. Thats forty times more than copycad. In that case light bulbs won't do you much good.
Old 09-28-2006, 11:22 AM
jimcarry's Avatar
Moderator
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
remember with copy chrome use 1 amp per 32 sq inches
so if your part is say 56 sq inches
you would tak your sq inches 56 devided by 32 the answer is 1.75 amps allways round down not up in this case i would use 1.5 amps to plate this piece
Jim Eaton
Old 09-29-2006, 07:07 AM
shawnkloker's Avatar
shawnkloker is on a distinguished road
I found out the hard way that too much current is bad.I am using a 5 amp power supply with a built in amp and volt gauge.
Old 10-04-2006, 08:52 PM
mcaswell's Avatar
Caswell Inc Founder
See the video/tutorial on the webpage on controlling the power with light bulbs
Have A Web Site?
Plating Power Source. mtumbleson Electroplating Questions 2 09-07-2005 10:07 AM
12v power source using Nichrome?? phunkmastakrez Electroplating Questions 1 08-18-2005 05:18 PM
wire welder for power source elboriqua Electroplating Questions 2 11-04-2003 06:25 PM
Heat Source txskinney Powder Coating Questions 3 07-05-2003 10:54 PM
Power source question spectraflamed Electroplating Questions 2 04-07-2002 06:56 PM
