Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Copy Chrome Kit Customers Only
Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit.
Old 07-27-2006, 09:32 AM
aptl1
Default question regarding long storage of solution
Hello, I have a copy chrome kit that I havent used in two years. When I opened the container with the solution it was still green however there was a 1/4" or so of a caked residue on the bottom of the container. Is this normal? should I reagitate it back into the solution or is this some sort of contaminate from previous plating projects? Thanks for your input
Old 07-31-2006, 12:45 PM
jimcarry's Avatar
Moderator
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: question regarding long storage of solution
My suggestion would be to add the d/s water that has evaporated heat the solution up to approx 170 or better while cooling be sure to stir the solution to help dissolve the crystals . Let the solution sit for 24 hours to cool then heat to 75 to 110 and plate a dummy item to check for brightness add brightener as needed
Jim Eaton
Chrome and Nickel Removal Question (long) bentley86 Electroplating Questions 5 03-19-2006 04:32 PM
Gold solution seperated.... idahodewitt Electroplating Questions 0 01-21-2006 05:07 PM
Nickel Plating long tube Gabourie Electroplating Questions 1 10-12-2004 08:02 PM
Odd shape question carmelmike Electroplating Questions 2 03-17-2003 10:08 PM
solution question tool_man Electroplating Questions 1 02-15-2003 01:32 PM
