Go Back   Plating Powder Coating Buffing Anodizing - Caswell Inc. Metal Finishing Forum > Electroplating Questions > Copy Chrome Kit Customers Only
Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit.
Old 08-16-2006, 12:43 PM
ecollins
Default Preparation question
Hi, I just ordered a copy chrome plug and plate kit and have some questions about preparation. Here's the steps I plan to use for mostly bolts, washers and large nuts.
1. Clean/Sand and Buff Part.
2. degrease w/comet mixed with warm water. (1/2 hour soak)
3. Remove rust in muriatic acid/water.
4. dip in degreaser solution.
4. Spray part with distilled water.
5. Plug N plate.
Does this sound right? After I spray part with distilled water, should I let it dry then plate? Or can I plate right away after the distilled water spray? Thanks and wish me luck.
-ecollins
Old 08-16-2006, 01:35 PM
jimcarry's Avatar
Moderator
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: Preparation question
1 Remove Rust
2 Clean/sand and polish
3 soak in degreaser after soak use a old wash cloth and clean the part with the Sp
4 Rinse in distilled water do water test (explaned in manual)
5 Go directly to plate
Jim Eaton
Old 08-16-2006, 01:38 PM
lcaswell's Avatar
Caswell Inc President
If you plan on blasting, always degrease first so you don't impregnate grease and oil deep into the metal during the blasting process.
Lance Caswell
Have A Web Site?
powder coat removal question eliasson Powder Coating Questions 29 04-20-2007 08:28 AM
Plating preparation black Caterpillar bolts borgen Electroplating Questions 1 02-27-2006 07:30 AM
electrical question bryceballard Powder Coating Questions 2 02-24-2005 05:59 PM
Peak voltage question mudwhump Anodizing Questions 6 01-14-2004 10:53 PM
Brand Newbie Aluminum Polishing Question gdsegel Metal Polishing Questions 1 04-25-2003 08:04 AM
