Go Back   Caswell Inc. Metal Finishing Forums > Electroplating Questions > Copy Chrome Kit Customers Only
Connect with Facebook
Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit.
Closed Thread
Old 10-12-2006, 10:10 PM
shawnkloker's Avatar
shawnkloker is on a distinguished road
Default yellow tint?
Is anybody else having trouble with their copychrome turning a yellow tinted color after being outside exposed to the weather after about a week?
Old 10-13-2006, 08:30 AM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: yellow tint?
Shawn
I’d like to see the piece you are talking about . Im also wandering if you are putting any thing to protect the part after plating and then again about three weeks later should use a once a year car polish or collinite metal wax or if maybe your plate was not thick enough or if this was a part you did while your tank was contaminated lots of questions here give ma call if I can help
Jim Eaton
Old 06-11-2007, 02:48 PM
jandjwoodwinds is on a distinguished road
I have also run into the yellow tint issue on some custom motorcycle parts using a nickel base and copy krome. I need some ideas so I can keep customers happy.
HIS,
Doc
www.JandJWoodwinds.com
JandJ_Woodwinds@bellsouth.net
318-780-9098
Old 06-15-2007, 09:08 AM
jimcarry's Avatar
Hey guys wats up
the yellow tint could be caused by metals left in the plating solution after you have plated an object please be sure you are filtering your solutions to prevent these metals from building up on the bottom of your tank these metals will rust and be plated on to future items
Jim Eaton
Old 06-16-2007, 01:01 AM
Hi Jim,
Thanks for the info. The only problem is that it was the first job through the solution!
HIS,
Doc
Old 06-16-2007, 05:48 AM
KCV6's Avatar
Moderator
Having investigated this problem myself, I have come to the conclusion it is because we are not plating withing the optimum temperature/ASI window for our tanks. Copy chrome is a Nickle Cobalt Alloy, NiCo with unfortunately a very high ratio of Cobalt salts (assumption), hence the solution being so red (assumption). Nickle and cobalt plate at different rates (fact). If too much cobalt is crystalised with the nickle it will tarnish yellow (assumption based on some knowledge. LOL).
Unfortunately increasing the temperature of a NiCo mix will make it throw further, but it will also change the ratio of the NiCo alloy. Changing the ASI will also change the ratio.
About all I can suggest is to try what has worked for the likes of Jim and others and fine tune it to suit your needs. Unfortunately metal plating is an art. Here is a good trick that all good plating shops use. Get a Notebook and for every piece you do, write down exactly what the temp of the solution was and try to calculate the ASI as accurately as possible and write it down. If you have a digital camera, take a pic of the item with a ruler for referance and keep this pic, put all this info into a spreadsheet linked to the pics. Eventually you will come up with the perfect combination that you can refer back too. Even better you will be able to work out trends as to what to expect in the way of results.
If you are selling plated items, as many seem to be doing on here, this info is also valuable as you can produce professional reports for customers on their items you have plated.
Just persist with it, Also tanks tend to improve with age.
Cheers
Mark
Old 06-16-2007, 10:21 PM
tbreaden is on a distinguished road
I had this problem about 4 months ago. I had not been plating much over the winter, my tank set for about 6 weeks at 40 deg. I have the wheel chroming kit and was told the larger kits like mine are cobalt only. I cleaned tank and found a rusty sludge in bottom. Now I run a filter when plating and remove anodes and clean after every use. Bath temp 70 to 80 deg. and make sure you have a good sealed anode bags. I have not had any problems since. (except plating pot metal) Todd
  #8 (permalink)
Old 07-23-2007, 11:30 PM
john1951 is an unknown quantity at this point
Hi I have the same problem even with the very first items I plated. I followed the temps and amps per the directions . Had the slight yellow tint right after buffing the parts. not as white as real chrome. Some types of lights make it look much wurse than others next to the triple chrome stuff on my bike. I waxed it and still no difference.
Closed Thread
Copy Cad - Yellow Chromate does not stay on charlton Electroplating Questions 1 07-31-2005 12:52 PM
Copy Cad kit - blackener and yellow cad durability problems Broke Electroplating Questions 11 01-09-2005 11:19 AM
Yellow NiteMare is Over It's DONE !!!! :) hvac36 Powder Coating Questions 4 12-10-2004 05:29 PM
Yellow Chromate on Galvanized? Rickc Electroplating Questions 0 01-31-2004 06:19 PM
Yellow Chromate & Copy Cad aermakov@rogers.com Electroplating Questions 3 03-03-2003 07:28 PM
