+ Reply to Thread
Results 1 to 6 of 6
Thread: Copy Chrome Problems Need Help!!!!!!
  1. #1
    Join Date
    Oct 2006
    Posts
    70
    Default Copy Chrome Problems Need Help!!!!!!
    I have been doing copy chrome for over a month, doing small handles 4 at a time. For the most part everything has been coming out perfect, but today my parts started to turn an odd color on one side. As I tried different things (less current, more current, higher temp, lower temp) It progressively got worse. I'm hoping that its just a brightener issue. I'm new to this and I haven't added anything to the original solution. Any help is appreciated. Thanks.
    Attached Thumbnails Click image for larger version
ID:	598   Click image for larger version
    Share with Facebook
  2. #2
    Join Date
    Jul 2004
    Location
    Arkansas
    Posts
    295
    Default Re: Copy Chrome Problems Need Help!!!!!!
    From experience this is what I can tell you if this buffs off then it is simply a prep or plating problem if it remains after buffing then you will have to add more brightener
    Jim Eaton
    Share with Facebook
  3. #3
    Join Date
    Jun 2004
    Location
    levittown PA
    Posts
    130
    what was your fix?
    D.I.L.U.S.I.
    Drive It Like You Stole It
    Share with Facebook
  4. #4
    Join Date
    Oct 2006
    Posts
    70
    brightner and a ph adjustment seemed to fix the problem.
    Share with Facebook
  5. #5
    Join Date
    Apr 2007
    Location
    Adelaide, Australia
    Posts
    247
    Just out of curiosity Z,
    With the low brightner problems you experienced, did you find that the CC tarnished with water or finger prints as well? This is a question often asked, but can not find an answer in the forums. Would appear it was usually solved over the phone.
    Jim may be able to shed light on this?
    cheers
    the convict
    Share with Facebook
  6. #6
    When plating with the copy chrome you need to plate for about 90 minutes to get a thick plating. If the parts are coming out with a slight haze on the item and it buffs off easily then it is fairly normal. If your parts are coming out consistently dull then brightener should be added. The brightener will deteriorate over time and needs to be replenished.
    Craige Brooks
    Have A Web Site?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. triple chrome vs. nickel/chrome vs. copy chrome
    By spectraflamed in forum Electroplating Questions
    Last Post: 01-21-2007, 10:07 AM
  2. Copy chrome concern
    By jbvan in forum Electroplating Questions
    Last Post: 01-18-2007, 07:20 PM
  3. copy chrome vs triple chrome plating
    By splbnd27 in forum Electroplating Questions
    Last Post: 06-21-2006, 07:35 AM
  4. copy chrome and aluminum problems
    By jtagger19 in forum Electroplating Questions
    Last Post: 08-14-2004, 06:15 AM
  5. Copy Chrome Start-up
    By Elitefisherman in forum Electroplating Questions
    Last Post: 04-18-2004, 04:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
