| Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit. |
I have a 4.5 copy chrome kit doing a mostley aluminum. The first few came out good but now having problems with rough plate on some areas. looks like the surface creaters of the moon to frost on a window in the winter Tried every thing,from higheer temp to lower amps and double etching and zinkateing. Most of the time I have a dark haze on when I pull I out of the bath, buffs off ok, . I am not flash copper plating first and was wondering if I did flash copper plate first would that relieve those problems. My steel and copper things are fine. Please help any one !!!!!!
Hi guys, am new here, but had exactly the same problems on almost any underlying metal type. After much playing around I came to the same conclusions as Curtis. Flash copper (then lightly polished without going through) prior to CC which gives a better finish straight out of the Tank. A second apparent advantage to the flash copper is the CC seems to throw further onto the copper in tight spots. However still had some issues with the areas of grey haze which also polished out fine. Tried everything and finally got a PH meter and checked my CC mix. It was at a PH of 6! Added a small amount of acid slowly until the PH was at around 3.5 and hey presto nice bright flawless CC. May be worth a check if you havn't already.
Cheers Mark |
| Copy Chrome Needed | Lt_Dan | Copy Chrome Kit Customers Only | 4 | 04-04-2007 10:55 AM |
| Copy chrome concern | jbvan | Electroplating Questions | 2 | 01-18-2007 07:20 PM |
| copy chrome vs triple chrome plating | splbnd27 | Electroplating Questions | 18 | 06-21-2006 07:35 AM |
| copy chrome over silvaspray-help needed | chrisk | Electroplating Questions | 1 | 08-25-2005 10:00 AM |
| Copy Chrome Start-up | Elitefisherman | Electroplating Questions | 10 | 04-18-2004 04:24 AM |
