+ Reply to Thread
Results 1 to 3 of 3
Thread: Advise needed.
  1. Join Date
    Jun 2008
    Location
    Comber
    Posts
    4
    Advise needed.
    Hi all,
    I'm new to the forum and to copy chrome but just some advice needed on copy chrome kit.
    1. When starting out do I mix all the kit solution up and work with that.
    2. If I make up all the kit solution is it possible to measure out a small amount for use with some small pieces, without having to use the full kit amount.
    3. In my kit I have a bottle of brightener is all this added to the kit solution mix or is there brightener already in the mixture and this is only for topping up the solution when required.
    The parts I have for chroming are small pieces from a 1955 motorcycle, a horn grill, a headlight rim all slightly worn with a brass type colour underneath, and some handlebar bits that have chrome missing and they are a steel base.
    What would be the best way to remove the existing chrome prior to copy chrome.
    You guys know have the knowledge and a learner would sure apprecitate some help and advise.
    Thanks
    Jim
    Share with Facebook
  2. Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    471
    Re: Advise needed.
    Quote Originally Posted by vulcan View Post
    Hi all,
    You can, or you can mix it up in ratio to make a smaller amount. Directions are on the label and in the manual.
    Sure.
    There is no brightener in the mixture already.
    Use chrome stripper to reverse plate the chrome off. Instructions for use are in the manual.
    Lance Caswell
    Have A Web Site?
    Share with Facebook
  3. Join Date
    Jun 2008
    Location
    Comber
    Posts
    4
    Re: Advise needed.
    Hi Lance,
    Many thanks for your help it's much apprecitated.
    Jim
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Plating toy advise, please
    By evilgordo in forum Electroplating Questions
    Last Post: 07-30-2007, 03:14 PM
  2. advise needed
    By gm_geek in forum Copy Chrome Kit Customers Only
    Last Post: 12-11-2006, 04:46 PM
  3. Caswell, please advise
    By Shawn60 in forum Metal Polishing Questions
    Last Post: 07-06-2004, 09:24 PM
  4. nickle plating over engraving/etching,advise needed
    By rbent in forum Electroplating Questions
    Last Post: 12-20-2003, 10:53 AM
  5. Advise Needed! Hobby or Business?
    By mccain1976 in forum Electroplating Questions
    Last Post: 06-09-2003, 10:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
