I would like to chrome plate a copper assembly I have constructed out of plumbing pieces. The assembly consist of a 1/2" copper tube 4" long with a cop on one end and a female adapter on the other end. If this works I would like to be able turn this into a consumer product and would need to generate hundrerds. The properties I need are a shiny chrome finish. The pieces will not be subject to a significant stress. Operating temperatures will be less than 120°F and pressures will be nearly 0 psi. This is a decorative plating only. I am looking for the easiest and most economical product.
