| Copy Chrome Kit Customers Only A dedicated forum for owners of our general Copy Chrome and Wheel Copy Chroming Kit. |
From Physical Properties of Titanium and Its Alloys
Titanium is not a good conductor of electricity. If the conductivity of copper is considered to be 100%, titanium would have a conductivity of 3.1%. From this it follows that titanium would not be used where good conductivity is a prime factor. For comparison, stainless steel has a conductivity of 3.5% and aluminum has a conductivity of 30%. It'll work, but the amps you provide won't all make it to your part. You would be best off to submerge the titanium with a copper wire, then you'll be fine. It's rather expensive, be sure to consider that.
James Bateman |
Thank you, maybe I should just stick with the copper, I like the titanium because it holds its shape so much better than copper so it's a lot easier to attach to the part by making a spring on the end.
I already have the titanium, that's what I use for anodizing. |
Okay, now I got it, thank you. I'm plating strictly small low amperage stuff, the Glock side I just did required 2.5 amps. I understand if I go bigger I'll need larger wire (the 1/2" copper hook) , I work with amperage and wire daily.
Unrelated to my last question, In the plating manual one symptom of a bad plate (forgot which one) is caused by copper in the bath, if we have copper extending into the bath are we not going to get copper in the bath? |
I have no idea what the resistance of the titanium is that you are using, but a 2.5 amp load you are putting into the titanium will quickly drop, and less is actually reaching your part, which will affect plating thickness. You could figure it out with a multimeter, or I'm sure that if you looked up the resistance of you wire size you could figure it out that way too. As I'm sure you are aware of, but I'll throw it out for public view, if the wire is getting warm/hot it's resisting the current and you are shorting what's supplied from the rectifier. After it is submerged the heat dissipates into the solution, so it's no longer a problem.
As far as the copper - it'll cause dark areas if I remember right. As long as the copper has a negative charge you're fine, like when you plate over flash copper, or acid copper. A couple things might cause you problems though. Let's say you make a hook, and the plating solution splashes up onto the hook. You'll have an acidic liquid on the hook. The splashed stuff evaporates a little - things are hot, etc... So now it becomes a little more concentrated and dissolves a bit of the copper, which then drips/falls back into the solution. That will potentially cause a problem, but it would be plated right out, so I wouldn't be too concerned about it. The big concern would be from incomplete rinsing after a pickling session. It's strong enough that it slightly etches the metal, and if you don't rinse everything off, the "pickle juice" left on the part (which is full of metal now) leeches out into the solution - that could be enough to cause a problem, not to mention how quickly that would screw up the ph of the plating bath. Hope this helps to dispel concerns. Jimmy. Quote:
James Bateman Last edited by woodjames; 05-19-2009 at 09:53 PM. |
Only if it's on the positive side. Hanging parts from copper wire is never an issue.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
| Titanium Wire For Anodes | kingkat | Electroplating Questions | 5 | 02-05-2009 08:58 PM |
| Titanium wire spring clips | rclint | Anodizing Questions | 12 | 01-18-2009 02:43 PM |
| Titanium wire | ken_the_stp | Anodizing Questions | 5 | 09-26-2007 09:18 AM |
| Anyone have Titanium wire for sale | SX Paintball | Anodizing Questions | 2 | 04-20-2007 12:55 PM |
| cheap titanium wire | kosdesign | Anodizing Questions | 0 | 08-30-2006 01:00 AM |
