Connect with Facebook
Old 07-23-2003, 07:26 PM
neil
Default Dull black parts when taken out of nickel bath.
I'm getting dull black spots on my nickel plating that are impossible to buff out? anybody know what they are.I,ve double checked all my settings (amperage,temp).The part is fully polished before it goes in bath but when it comes out its shining on one side of the piece and has random dark dull spots on the other.I have stripped it several times and started over with the same results.Help!!!!
Old 08-04-2003, 11:05 AM
Shevalik
Are you going in live? This might be the cause. You should have the current on during the entry into the tank. I would also check your connections, I run my bath temp at 125. Anything lower than that and I start to have to dull plating, black spots etc.
Old 03-29-2009, 01:22 AM
NOL4154's Avatar
NOL4154 is on a distinguished road
Thumbs up Re: Dull black parts when taken out of nickel bath.
Hello,
Important questions, what is your base metal steel, brass, diecast?
It appears to be brass! If brass, sometimes lead in the brass material will diffuse through the nickel plating casing black spots. If you copper plate a layer, polish and then nickel plate. If no black spots appear it was your base metal. Just a trouble shooting tip before you toss your nickel out.
Good Luck,
Nol4154
Old 03-29-2009, 01:34 AM
woodjames's Avatar
woodjames will become famous soon enoughwoodjames will become famous soon enough
Default Re: Dull black parts when taken out of nickel bath.
Could be contamination of other metals in the tank. Dummy plate before you try any more pieces.
James Bateman
Nickel bath inexplicably quits plating jackf Electroplating Questions 8 10-17-2009 06:39 PM
Did I mess up my nickel bath? Shevalik Electroplating Questions 4 03-29-2009 01:14 AM
Black Krome PnP over Nickel PnP (brass revolver frame)? arcom Electroplating Questions 0 02-01-2005 12:18 PM
Lead contamination of nickel bath? hakelly Electroplating Questions 2 12-21-2003 05:58 PM
I think I ruined my nickel bath Tad Anderson Electroplating Questions 1 05-24-2003 11:28 PM
