+ Reply to Thread
Results 1 to 4 of 4
Thread: Re-plating new electroless nickel
  1. Re-plating new electroless nickel
    Hi,
    Is it ok to immediately (within a few days) re-plate new electroless nickel? I've just plated a part and decided that I want to sand smooth some defects (not all the way to the steel just smooth it out) and re-plate. Can I do that by the same process I used to plate the part the first time? Thanks so much.
    tom
    Share with Facebook
  2. Join Date
    Sep 2005
    Location
    South Texas
    Posts
    885
    Re: Re-plating new electroless nickel
    You'll need to clean and activate the nickel plate but you can plate over it. Any time the nickel is exposed to air for more than an hour, consider it "dirty". For aluminum, it's minutes. You can dip the item in diluted sulfuric acid for about 30 seconds to activate it. Spray rinse and WBT then go directly to your plate tank.
    Share with Facebook
  3. Re: Re-plating new electroless nickel
    Thanks so much. I'm very pleased. This is the only forum I've been member of that was actually responsive and helpfull.
    Share with Facebook
  4. Join Date
    Sep 2005
    Location
    South Texas
    Posts
    885
    You're welcome. We all hope you come back and pass the favor on to someone else. We all learn something from reading posts. At least 35 other people have read it already.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Electroless Nickel Plating
    By rickjester in forum Electroplating Questions
    Last Post: 04-06-2009, 11:11 AM
  2. Help !!! - Electroless Nickel Plating
    By nmbapat in forum Electroplating Questions
    Last Post: 11-16-2006, 09:03 PM
  3. electroless nickel plating
    By woody44 in forum Electroplating Questions
    Last Post: 04-21-2005, 10:43 PM
  4. electroless nickel plating
    Last Post: 04-21-2005, 10:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
