Old 03-13-2002, 09:40 PM
antqoutb
Send a message via AIM to antqoutb
Default Plugs
I'm about to plate a couple of engine cylinders from an antique outboard. They are cast iron with steel sleeves. The original finish was dull nickle and I hope to duplicate it. I obviously do not want to plate the inside of the cylinders. Can plastic plugs be used? If not, are there easy to remove coatings that I can use?
Old 03-14-2002, 01:08 AM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Plugs
Yes, you can use plastic plugs. You can also use a lacquer based mask...see the discussion board for new products below.
Have A Web Site?
Rechrome exhaust on an'86 Suzuki Intruder dperk Services Offered/Wanted 20 07-24-2005 01:22 AM
Problem with press fit plugs mtarrant Anodizing Questions 1 07-20-2005 12:33 AM
