1. Make your plating times based on the thickness of the plate required for your needs. I wouldn't worry about seconds. THEN calculate the credits necessary for the part(s). Plating thickness will depend on the use of the part. Too thin and it will wear off with use and/or provide little corrosion resistance.
2. Leave the part in for the duration of the plating cycle. Add the mixed replenisher a little at a time throughout the cycle.
3. Mix only what you'll use for the plating session.
4. I've had a batch sit idle for 4-5 months and it still performed well. I've had unmixed chemicals for over a year and they still plate perfectly. (Parts A, B & C)
Caswell indicates a bath can be used for about 10 sessions. I've gone quite a bit more with good results. The accuracy of your credits plays a big role on how long the bath lasts. The EN process is more tolerant with too much replenisher than it is being low. Also, how you care for the bath by not dragging other compounds into the batch makes a huge difference. Zinc, rust or cleaners/degreasers can ruin a bath in a hurry. The mixed bath is good until it starts to cloud. Once the bath becomes clouded, it's plating effectiveness drops sharply. (More than 50%) This is because of the formation of other compounds in the bath. The cloudiness is a normal reaction from using the electroless process. When it occurs, use the disposal process for the old batch then mix a new new batch.
LinkBack URL
About LinkBacks
