+ Reply to Thread
Results 1 to 8 of 8
Thread: how to remove nickel, detailed instructions needed
  1. #1
    Default how to remove nickel, detailed instructions needed
    I need to remove 90 year old nickel and copper from some old steel parts. The Caswell guide that came with my kit doesn't give many details about how to do it. Can anybody give me all the info, such as: what solution to use, what temperature & time, what amperage per square inch, etc.
    I'd prefer not to use sandblasting or mechanical abrasion, or to minimize the amount of those efforts needed.
    thanks
    Pete
    Share with Facebook
  2. #2
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    886
    Default Re: how to remove nickel, detailed instructions needed
    Share with Facebook
  3. #3
    Join Date
    Nov 2005
    Posts
    945
    have fun with that! i just bashed my head against the wall trying to remove nickel and copper from pot metal harley parts. you're in a much better position with a steel substrate. the metal-x stripper worked great for the nickel. the copper was the bear, but pot metal gets eaten up by anything that can strip anything. for the copper, i read you can use ammonium persulfate or sodium persulfate. in the end i used a flap wheel to remove the copper. i came off easier than i initially thought it would. blasting is not a good solution in my opinion.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
    Share with Facebook
  4. #4
    Hi Carwiz. I bought a kit for nickel plating, and another for flash copper. Ihave lots of old motorcycle parts that need plating, mostly on steel, some iron, some copper, some pot metal, etc.
    On this forum, I've read a few references to pickle #1, #2, etc, and read that reverse electroplating will remove nickel and copper, but I'm still hoping to get some details about how to set it up. My Caswell guide doesn't mention the pickels, except to say that Caswell doesn't recommend them anymore. I really thought that the Caswell guide would have more info, but it doesn't have much other than a description of how to etch nickel before putting on a new coat....
    If anybody can help, I'd appreciate it. I have a few hundred small, expensive parts that I don't want to blast, grind, or sand.
    Share with Facebook
  5. #5
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    The only way to strip steel is to use a high concentration of sulfuric acid with glycerin to prevent pitting. You can go with what the manual says but your steel will pit severely, as in beyond recognition. Invest in MetalX strippers. The copper works exceptionally well, along with the nickel which is just as good. Especially if you're talking expensive parts. I've tried other methods, and feel free to try them to, you'll regret it as much as I have.
    The metalx nickel stripper works by immersion, the copper works through reverse current. Best part about the copper is that you can plate it out of the solution, so it'll last a very long time.
    Quote Originally Posted by knossos View Post
    James Bateman
    Share with Facebook
  6. #6
    Thanks James. I'm glad to hear that you have tried the various methods. It seems that there is a lot of stuff written on the internet, but without much details. I thought that commercial platers used reverse electroplating, but maybe they use something like metalX.
    I was hoping to try the methods that I've heard were in the Caswell manual, but there just isn't much info in there. Maybe in the older editions, when they used Pickle#2 or whatever. Now it just has a few lines of text, saying to buy metalX, not much info to go on.
    I'll try the metalX products. I was hoping to avoid buying one product for copper strip, and another for nickel strip on steel, and a third product to strip nickel from brass.... And I haven't even gotten into stripping cadmium and zinc yet! I'm going to end up with 16 tanks and heaters when I'm done.
    Pete
    Share with Facebook
  7. #7
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    16 tanks? I remember those days. Just wait.
    You can use reverse plating, which would be with concentrated sulfuric and an inhibitor. There'd be some trial and error to, where the Metalx solutions are pretty much foolproof. That and it's easy at first to make a few booboos when you plate, and it's nice to have a way to.....erase them.
    If I remember right Pickel #2 is about 10%HCL, best used to activate copper. Problem is it's a bear to strip nickel, but steel just loves to dissolve in there. Even if you stand there and watch it, the plate will get undercut a bit, and there goes your steel!!!
    On second thought, I think 10% HCL is pickel 1, and 10% sulfuric is pickel 2. I'll double check and write back if this is wrong.
    There might be some places using r.p., but oftentimes on the professional forums I see many references to MetalX products.
    Zinc's easy - immerse in 10% sulfuric and wait till it stops fizzing. You can use the same concentration for activating steel, copper, and nickel, so it'd be a 4 in 1 bucket.
    -Jimmy.
    Pete
    James Bateman
    Share with Facebook
  8. #8
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    use the metal x , its the way to go, i mix mine in steel stock pots and use hots plates with built in thermostats, i dont use the copper formula only 9 and 929
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. remove or not remove old nickel
    By francisb44 in forum Electroplating Questions
    Last Post: 01-12-2009, 12:31 PM
  2. Is There A Better Way To Remove Tarnish From Nickel?
    By HowdeeDoodee in forum Metal Polishing Questions
    Last Post: 01-29-2008, 06:17 AM
  3. Detailed oven plans
    By lightningracer in forum Oven Building Forum
    Last Post: 01-14-2006, 11:33 PM
  4. Golf Clubs - How to remove nickel finish prior to refinishin
    By doctordave in forum Other Metal Finishing Questions
    Last Post: 06-03-2005, 03:21 PM
  5. help need instructions for electroless nickel plate
    By plater12 in forum Electroplating Questions
    Last Post: 06-23-2004, 08:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
