Connect with Facebook
Old 10-23-2009, 04:39 PM
woodjames's Avatar
woodjames will become famous soon enoughwoodjames will become famous soon enough
Default Plating a spring?
What's the scoop on plating a coiled up spring? I've seen it done before. Does it have to be "stretched" out while plating? Thanks in advance.
James Bateman
Old 10-24-2009, 10:53 AM
NOL4154's Avatar
NOL4154 is on a distinguished road
Thumbs up Re: Plating a spring?
James,
First, what is the purpose of the spring? Second, what type of plating?
What you need to known is that plating has internal stresses and need to be control. Write back
Nol4154
Old 10-24-2009, 12:39 PM
woodjames's Avatar
Default Re: Plating a spring?
Copper nickel chroming a return spring for a brake lever. The lever is depressed and the spring returns it's position.
Originally Posted by NOL4154 View Post
James,
Nol4154
James Bateman
Old 10-25-2009, 01:52 PM
NOL4154's Avatar
James,
I am assuming that it is carbon steel. You can plate the spring but make sure your nickel brighting system will give a good ductile nickel. The hard part is plating in the areas of low current density. Your rack may need some thought in order to place extra anodes for coverage in the hard areas. I been visiting some plating shops and have seen interesting racks for springs, bearings, etc... Good luck.
Nol4154
Old 10-29-2009, 09:06 AM
lcaswell's Avatar
Caswell Inc President
You don't need to stretch it out - just plate it normally.
Lance Caswell
Have A Web Site?
Old 10-29-2009, 03:58 PM
CarWiz's Avatar
Caswell Platinum Member
I like to stretch the extension springs a little. It keeps the plate from bridging the contact point and making for an ugly plate and possibly creating unplated areas. Compression springs are already open except the ends. The LCD areas between the coils are really negligible on all but very large springs (suspension, etc.) The area is normally covered by the throw and ions from the solution.
Old 11-01-2009, 11:49 AM
NOL4154's Avatar
James,
The scoop on plating on springs. First what is the spring being used for.
If the spring is going to be exercise (meaning going to be press and release) alot. The choice of plating is important because you do not want it to peel or crack. Nickel sulfatemate or electroless nickel is the choice. The secret is the stress placed on the plated layer. No you do not stretch the spring.
Nol4154
James Bateman
  #8 (permalink)
Old 11-01-2009, 12:17 PM
woodjames's Avatar
That makes sense. Often times the wire that I use to hang the piece cannot take being bent too much, cleaned and activated along with the workpiece. I'll see if I can find someone to Electroless nickel the pieces for me. I'm pretty sure Carwiz does electroless, maybe I can work something out with him...
James,
Nol4154
James Bateman
James Bateman
Best way to calc. suface area of MC spring? timbn2 Electroplating Questions 3 10-14-2009 02:01 AM
Titanium wire spring clips rclint Anodizing Questions 12 01-18-2009 02:43 PM
Suzuki GSXR Spring in FiRe Red FiReBReTHa Powder Coating Questions 0 06-01-2007 10:39 PM
Coating a spring Millermatic Powder Coating Questions 12 05-27-2006 10:55 AM
Spring/ Bottled water? yoyoboy Anodizing Questions 14 02-15-2006 11:00 PM
