Connect with Facebook
Old 10-31-2009, 12:42 AM
eojthekid is on a distinguished road
Default HELP! power supply
MODE: NSP-2050/3630/6016
what do i do with number 8 GND , I am using copy chrome kit don't i just use + and - ?
[IMG][/IMG]
􀁣 Power Switch :
Turns the power supply on–off, when it is on the front display lights up.
􀁤 AC Input Socket with Fuse
􀁥 Concealed Fuse box ( ply open the cover to get to the fuse)
􀁦 Output Voltage Tuning knob
􀁧 Output Current Tuning knob.
􀁨 Output On/Off push button
􀁩 Output Terminal Positive (+) Red color.
􀁪 GND Terminal () Green color
Chassis ground terminal, normally this is to be short to (+) or (-) as required by user.
􀁫 Output Terminal Negative (-) Black color.
􀁬 LCD Display panel showing :
4 digit voltage, current meter, (CV) constant voltage mode, (CC) constant current mode,
Output Terminal on/off state
OPERATIONS
Ground Connection
Old 10-31-2009, 06:43 PM
Default Re: HELP! power supply
My power supply doesn't show the C.C. it only shows the C.V. do i have to shorted out my black wire by touching the GND OUTPUT ?
OPERATIONS
Ground Connection
Depending on the application, the power supply output terminals can be grounded in any one of the following grounding
conditions :
Negative ground – black (-) negative terminal is shorted with green GND terminal.
Positive ground – red (+) positive terminal is shorted with green GND terminal.
Floating ground – green terminal is not shorted with any of the output terminals.
Remarks :
When operating this power supply as a floating ground, high impedance leakage can exist between the power supply circuitry
and the chassis ground.
Basic Mode of Operation
This power supply is designed to operate as a constant voltage source or as a constant current source. Automatic crossover to
either mode of operation occurs when the load condition changes as following :
Old 10-31-2009, 11:33 PM
CarWiz's Avatar
Caswell Platinum Member
Is this a duplicate post?
No, don't connect the green post to anything.
I don't much care for the CC setup procedure (shorting leads) but it's described in your manual. Read the paragraph headed "Presetting Current Limiting Value (CC)". Most other power supplies have you turn the voltage knob(s) all the way up, current all the way down, turn on the PS then set the current with the amp knob(s). I'm not sure why they refer to the knobs as "volume". Probably a Chinglish translation.
http://www.caswellplating.com/kits/i...5ampccinst.pdf
Can i use this DC POWER SUPPLY..... CATS-PURRFECT Electroplating Questions 10 05-07-2009 04:04 PM
new need help with power supply cowboy1ht Anodizing Questions 5 03-14-2009 01:52 PM
Which Power Supply? kohnsports Electroplating Questions 1 01-13-2009 07:57 PM
Power supply paintballkidz Anodizing Questions 16 09-24-2008 10:26 PM
power supply jamerson Anodizing Questions 8 05-07-2005 04:43 PM
