+ Reply to Thread
Results 1 to 2 of 2
Thread: HELP! power supply
  1. #1
    Default HELP! power supply
    MODE: NSP-2050/3630/6016
    what do i do with number 8 GND , I am using copy chrome kit don't i just use + and - ?
    [IMG][/IMG]
    1- Power Switch :
    Turns the power supply on–off, when it is on the front display lights up.
    2- AC Input Socket with Fuse
    3- Concealed Fuse box ( ply open the cover to get to the fuse)
    4- Output Voltage Tuning knob
    5- Output Current Tuning knob.
    6- Output On/Off push button
    7- Output Terminal Positive (+) Red color.
    8- GND Terminal () Green color
    Chassis ground terminal, normally this is to be short to (+) or (-) as required by user.
    9- Output Terminal Negative (-) Black color.
    10- LCD Display panel showing :
    4 digit voltage, current meter, (CV) constant voltage mode, (CC) constant current mode,
    Output Terminal on/off state
    OPERATIONS
    Ground Connection
    Share with Facebook
  2. #2
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    Default Re: HELP! power supply
    I did some research, and found that it "8" becomes a common ground. It's useful for reducing electro-magnetic interference like the same "noise" you get out of audio systems sometimes. Not of much use to you and your application. Mine aren't hooked up, and have been using them for a while now. If you were running a computer off your supply or an amplifier it would be necessary. Don't worry about it.
    James Bateman
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. HELP! power supply
    By eojthekid in forum Electroplating Questions
    Last Post: 10-31-2009, 10:33 PM
  2. Power Supply
    By gordb52 in forum Copy Chrome Kit Customers Only
    Last Post: 02-15-2009, 05:22 PM
  3. Power supply
    By hurricaneracing in forum Anodizing Questions
    Last Post: 09-03-2006, 08:42 PM
  4. power supply
    By shawnkloker in forum Electroplating Questions
    Last Post: 07-07-2006, 09:21 AM
  5. New power supply?
    By Tim Wiltse in forum Anodizing Questions
    Last Post: 10-23-2003, 05:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
