Connect with Facebook
Old 11-06-2009, 04:48 PM
woodjames's Avatar
woodjames will become famous soon enoughwoodjames will become famous soon enough
Default Techno Weld
I'm posting this in case someone searches for it in the future....
Finally got around to trying Techno weld last night. I had to fill the HONDA letters on a motorcycle engine cover. Cast aluminum cover, high in silicone. Put the piece on the stove, and hit the area to be repaired with some propane from a torch too. Once it got up to temp, man the stuff stuck great. I started sanding down the area, and couldn't see much of a transition between the aluminum and the repair. I've really happy so far, should save some time trying to repair aluminum using regular solder and a copper plated surface.
I still have yet to try to plate over it, will post on that later - but if anyone has some info that would be helpful to plating it, please share.
James Bateman
Old 11-06-2009, 10:33 PM
CarWiz's Avatar
Caswell Platinum Member
Default Re: Techno Weld
I haven't used the brand but I've used the alumi-weld sticks quite a bit. Everything from fixing a lawnmower engine to repairing aluminum auto panels. Prep is everything for this type of repair. But as you, I haven't tried to plate it yet.
Hey Jimmy, did you get my message on the EN plating?
Old 11-07-2009, 06:04 PM
spankey666's Avatar
spankey666 is an unknown quantity at this point
ditto about the plating, but i have used similar ali welding sticks many times on motorbike radiators. i always carry some in the race kit just in case
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. " - Douglas Adams
The Darkside bdk Race Engineering
Slots and JB Weld? lsw11 Powder Coating Questions 26 03-27-2006 12:22 AM
JB Weld.. jagboy69 Powder Coating Questions 5 03-17-2005 12:07 PM
J B Weld Revisited rkolpack Powder Coating Questions 6 08-08-2004 09:35 AM
JB Weld Blademan Powder Coating Questions 11 05-08-2004 02:17 AM
Techno-Geek Questions edclark Electroplating Questions 3 01-14-2004 09:01 PM
