Fred Luhn Goldies Gold Plating Service New York http://www.goldiesplating.com 718-529-6655 Voice/Fax |
You should immersion nickel plate them (or electroless) immediately after Zincating. Then brush plate the gold onto the nickel.
Can the woods nickel strike used for brush plating be set up to tank plate for a one time use? Should it be diluted? If so how much and with water I Guess??
Sure. Use the solution as is.
Thankyou, THANKYOU, THANKYOU!"
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Need a couple of aluminum pieces plated: Dayton, Ohio area | jmmyjam | Services Offered/Wanted | 5 | 06-16-2005 10:44 AM |
| Do you have to use flash copper to plate aluminum | krsimulis | Electroplating Questions | 1 | 07-27-2004 01:32 PM |
| Plated Aluminum | Bullitt 3309 | Other Metal Finishing Questions | 3 | 02-10-2003 02:17 PM |
| Complete Newbie, How Do You Brush Aluminum? | G.D.P. | Metal Polishing Questions | 1 | 09-26-2002 10:28 PM |
