Results 1 to 5 of 5
Thread: Misting Balls
  1. #1
    gdenys is offline Platinum Member
    Join Date
    Dec 2009
    Posts
    1
    Default Misting Balls
    OK sorry but I can not figure this out. What do I use the misting balls for in electroless nickle plateing of brass?? This is my first time....so be gentle
  2. #2
    Brintiff is offline Amateur Metal Finisher
    Join Date
    Jul 2008
    Posts
    217
    Default Re: Misting Balls
    You put them in the EN bath, the balls float on top and reduce the fumes.
  3. #3
    NOL4154's Avatar
    NOL4154 is offline Amateur Metal Finisher
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Thumbs up Re: Misting Balls
    Hello,
    My first question why are you using mist balls? Is recommended by chemical technical data sheets? It may reduce some chemical reaction gas. Now, when you place a part into the EN tank do you see a lot small bubbles alike when you open up a soda bottle? If so, it would not hurt to use the mist balls because any out gassing is not health. Write back.
    NOL4154
  4. #4
    lcaswell's Avatar
    lcaswell is offline Caswell Inc President
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    643
    Quote Originally Posted by Brintiff View Post
    Actually, in the EN kit we use them to help maintain bath temp.
    Lance Caswell
  5. #5
    DaGunster is offline Newbie
    Join Date
    Jan 2010
    Posts
    12
    If I'm not mistaken, the idea of the misting ball is to reduce the surface area exposed to air.
    In hydroponic gardening, using styrofoam over the tanks reduces the surface of the water exposed to air - reducing the exposed area that can evaporate.
Thread Information
Users Browsing this Thread
  1. caswell balls
    By pyroracing85 in forum Anodizing Questions
    Last Post: 11-30-2009, 08:41 PM
  2. Mist Balls, Options without them?
    By Grumple in forum Anodizing Questions
    Last Post: 06-15-2008, 09:57 PM
  3. Mist balls
    By destroyer125 in forum Anodizing Questions
    Last Post: 02-26-2008, 08:47 AM
  4. fume balls?
    By skeleton in forum Electroplating Questions
    Last Post: 05-14-2003, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
