Results 1 to 3 of 3
Thread: electroless nickel
  1. #1
    jww225 is offline Platinum Member
    Join Date
    Nov 2009
    Posts
    1
    Default electroless nickel
    what is the main ingredient in the nickel bath disposal liquid?
  2. #2
    NOL4154's Avatar
    NOL4154 is offline Amateur Metal Finisher
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Default Re: electroless nickel
    Hello,
    EN mixture:
    Nickel Salts: Sulfate, Sulfamate, Chloride Source of nickel
    Reducer: Hypophosphite Boranes (DMAB) Reaction energy source for nickel to be available for reaction. "The Chemical Rectifier".
    Chelators/complexors: Citric acid, Lactic acid, Malic acid Allows controlled amount of nickel to be available for reaction. Avoids a runaway reaction.
    Buffers: Borate, Acetate, Succinate Inhibits dramatic pH changes
    pH regulators: Ammonium hydroxide
    Potassium carbonate
    Sulfuric acid To adjust and maintain the operating pH
    Stabilizers: Metallic - Pb, Sn, Mo
    Organic: S Compounds Plating rate control and prevent uncontrolled plate out
    Wetting Agents: bubble release and reduces pitting Controls solution's surface tension and H2
  3. #3
    lcaswell's Avatar
    lcaswell is offline Caswell Inc President
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    643
    Quote Originally Posted by jww225 View Post
    It's proprietary.
    Lance Caswell
Thread Information
Users Browsing this Thread
  1. Electroless Nickel
    By XK120DHC in forum Electroplating Questions
    Last Post: 06-24-2009, 11:08 AM
  2. Electroless Nickel kit not doing anything...
    By imsolidstate in forum Electroplating Questions
    Last Post: 04-28-2009, 11:22 AM
  3. electroless nickel replenishing
    By engine in forum Electroplating Questions
    Last Post: 12-31-2008, 10:46 PM
  4. electroless nickel vs regular nickel
    By Rocky in forum Electroplating Questions
    Last Post: 07-24-2003, 02:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
