Results 1 to 2 of 2
Thread: Newbie Question about a power supply w/zinc-cadmium set
  1. #1
    phk1967 is offline Newbie
    Join Date
    Mar 2010
    Posts
    5
    Default Newbie Question about a power supply w/zinc-cadmium set
    Since they're out of the rectifier I was going to buy I was wondering if I could use something like a 10v 1.5amp a/c adapter , an extenion cord with a dimmer switch set on low or a 12v battery for a power supply with the zinc cadmium kit. I'll be plating mostly small parts.
    Thanks.
  2. #2
    zincplater is offline Amateur Metal Finisher
    Join Date
    May 2009
    Location
    USA
    Posts
    171
    Default Re: Newbie Question about a power supply w/zinc-cadmium set
    Your best bet until the supplies come in would be some 1.5 volt batteries. You need to keep the voltage low and adjust the current. AA, C and D will work. You can connect a couple in parallel, too.
    IMO, the 3A supply is useless. Get the 5A unit....you'll quickly run out of current with the 3A model.
Thread Information
Users Browsing this Thread
  1. Cadmium/Zinc ?
    By JBM377 in forum Electroplating Questions
    Last Post: 01-05-2010, 11:46 AM
  2. power supply question
    By 91slicktop in forum Anodizing Questions
    Last Post: 12-12-2008, 05:36 PM
  3. Power Supply Alternative- Zinc Plating
    By dsalter in forum Electroplating Questions
    Last Post: 01-30-2006, 11:53 AM
  4. Power Supply Question
    By edwin247 in forum Anodizing Questions
    Last Post: 08-30-2004, 11:20 AM
  5. zinc vs cadmium plateing color
    By ckahler in forum Electroplating Questions
    Last Post: 04-27-2003, 11:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
