If you go here - Electroplating Current Requirement Calculator - Caswell Inc. - our tool will tell you how many amps you need to zinc plate something.
If you need to work out the surface area of your part, go can also go here - Caswell Inc - Calculating Surface Areas
LinkBack URL
About LinkBacks
