Results 1 to 2 of 2
Thread: Alkaline zinc plating and zinc generator
  1. #1
    Titangym is offline Newbie
    Join Date
    Mar 2010
    Posts
    23
    Default Alkaline zinc plating and zinc generator
    I trying to build medium dimensions of zinc electroplating and finishing with black tree valent cromatisation. bath should be 4ft long and 1,5ft wide 2 ft deep.
    I see in google serch that I need some Zinc geneerator system.
    I supose zinc genrator is another bath but I am not clear, in attachement is
    PDF with txt about zinc generator.
    Can someone guide me about this.
    Attached Files Attached Files
  2. #2
    XK120DHC is offline Experienced Metal Finisher
    Join Date
    Jul 2004
    Location
    Texas! Is there anyplace else?
    Posts
    282
    Default Re: Alkaline zinc plating and zinc generator
    Are you setting up a Commercial Zinc Plating line? Or are you going to do "Hobby Plating" on small parts?
    If you plan on doing Commercial Plating, I would attend the appropriate plating schools offered to learn all facets
    of plating, bath testing, knowledge of general chemistry, etc.
    If you are only going to do "Hobby Plating", go to Plating Kits Electroplating Kits Aluminum Anodizing Kits Powder Coating Systems Metal Polishing And Buffing Supplies - Caswell Inc., click on the plating tab, search for
    Zinc/Copy-Cad Plating and check-out the various size "kits" Caswell offers. No sense buying a thousand gallon
    set-up to plate a handful of nuts and bolts.
    The Zinc/Copy-Cad Plating Set-up is separate from the Chromates (Black, Blue, Yellow, etc.).. These are
    "after plate dips" that seals the zinc from sacrificing it's protection too fast, plus the Chromates look good.
    Determine what you are going to plate and Chromate FIRST, then go from there.
    Charles
Thread Information
Users Browsing this Thread
  1. Can I strip Zinc in my Zinc plating tank by Reversing electrodes
    By tfinklea in forum Electroplating Questions
    Last Post: 01-16-2010, 10:01 AM
  2. After zinc-plating...
    By paskharen in forum Electroplating Questions
    Last Post: 05-27-2009, 12:36 AM
  3. Help with zinc plating
    By monomanx in forum Electroplating Questions
    Last Post: 01-17-2009, 01:58 PM
  4. Remove Zinc Plating?
    By Gungineer in forum Other Metal Finishing Questions
    Last Post: 06-20-2008, 01:42 AM
  5. Can you use zinc wire for anode in Zinc Plating (copy cad)?
    By ms042180 in forum Electroplating Questions
    Last Post: 12-23-2006, 02:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
