Results 1 to 4 of 4
Thread: Need high temp chrome platable filler for steel
  1. #1
    kent_in_kc is offline Newbie
    Join Date
    Sep 2009
    Location
    Midwest
    Posts
    14
    Default Need high temp chrome platable filler for steel
    I make custom motorcycle pipes and need a filler for minor imperfections that can withstand up to about 1000F and be chrome plated. Alternately, I need a tinning or conductive paint to go over lab metal.
    I normally use lab metal with caswell ceramics and pc but some guys want chrome.
    I looked at the steel epoxy stick here but it doesn't indicate its temperature range or whether it is suitable for chroming.
    THanks for your help.
  2. #2
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Default Re: Need high temp chrome platable filler for steel
    It'd have to be a metal repair to do what you expect of it. I've seen some "softer" welding rods that would shape easily, but they're silicone based, and wouldn't plate well.
    Depending on just how deep the imperfections are, you may not need anything at all as copper can applied thicker to specific areas. Most likely you're best option is brazing. But if these are pipes that are new, why do you have imperfections in them?
    James Bateman
  3. #3
    Join Date
    Sep 2009
    Location
    Midwest
    Posts
    14
    The imperfections are small gaps in joints after brazing. Also when you cut a mandrel bend half way through it is slightly oval. Welding that to a straight (round) piece, leaves a small uneven spot that needs to be filled to look right.
  4. #4
    woodjames's Avatar
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    I see. I've seen on those hot rod shows that when the join bent sections, they use a tailpipe expander to make it round again.
    You might be best to find a braze at a slightly lower temp (but still above 1000F), sandblast the old stuff, and try to repair on top of the old. But if they offer such a thing, please state what it is in terms of composition, and I'll let you know how compatible it'd be with plating.
    Quote Originally Posted by kent_in_kc View Post
    James Bateman
Thread Information
Users Browsing this Thread
  1. High TEmp Powder
    By Luck_E in forum Powder Coating Questions
    Last Post: 10-07-2008, 10:41 AM
  2. high temp- how high? - will it burn?
    By mtnbiker in forum Powder Coating Questions
    Last Post: 09-26-2005, 11:47 PM
  3. PC over Liquid Steel filler?
    By Carcher7878 in forum Powder Coating Questions
    Last Post: 07-07-2004, 05:23 PM
  4. Looking for hi-temp filler
    By Hemi-T in forum Powder Coating Questions
    Last Post: 07-11-2003, 10:33 AM
  5. Can I use VHT high Temp with Krylon High temp radiator paint
    By magnus in forum Other Metal Finishing Questions
    Last Post: 05-03-2003, 11:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
