Results 1 to 4 of 4
Thread: Building a Fume Extractor
  1. #1
    morsemike is offline Platinum Member
    Join Date
    Mar 2010
    Posts
    2
    Default Building a Fume Extractor
    I want to build a fume extractor similar to the one diagramed in the Caswell Manual. It calls for an all plastic pump and a mist nozzle. I have not had luck finding those items. Anyone know where to get them?
  2. #2
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Default Re: Building a Fume Extractor
    Check harbor freight. The last pump I got was from there, and it had a bunch of accessories to setup up water falls and sprinklers with it - I'm sure you could make it work with a little creativity.
    Quote Originally Posted by morsemike View Post
    James Bateman
  3. #3
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Knowing what part of the World you're in might help answer your question.
    You can get misting nozzles at home centers. Look around the shop fan section. If you're in the Northern Hemisphere, this is the time of the year they'll be in stock. You can get a kit that comes with multiple nozzles, hose, fittings and a valve. You don't even need to run a pump. Just power the kit from a lawn hose. (That's what these kits are designed to use.) Dialed down, you get a good mist and it uses about five gallons of water all day with a couple of misters.
  4. #4
    Join Date
    Mar 2010
    Posts
    2
    Thanks for the suggestions - I'll check these out.
Thread Information
Users Browsing this Thread
  1. Replies: 3
    Last Post: 08-12-2010, 09:42 AM
  2. my new dust extractor
    By johnakay in forum Metal Polishing Questions
    Last Post: 02-11-2010, 12:23 PM
  3. fume control
    By lazz3125 in forum Anodizing Questions
    Last Post: 05-07-2004, 06:30 PM
  4. Fume Control
    By MrDmB in forum Other Metal Finishing Questions
    Last Post: 03-10-2004, 07:38 PM
  5. fume balls?
    By skeleton in forum Electroplating Questions
    Last Post: 05-14-2003, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
