Hi ! I want to purchase the plug and plate to do some nickel plating and gold plating.
How much area can i plate with the 4oz gold plating solution?
How much surface area can I get with the 8oz. nickel plating solution?
Can I use the same plug n plate wand to do both nickel and gold with a bandage change?
My intention is to plate copper traces on a circuit board with nickel first and then plate with gold on top of the nickel.
Can I plate immediately after plating with nickel.
Do I have to prepare the nickel surface before I plate with gold ?
I am not looking for a super fine finished look-but am concerned that if I have to treat the nickel before plating with gold that the treatment chemical will affect the glass epoxy board that I will be using and effect the copper traces etc..
Also will the plug and plate transformer that comes with the nickel kit be sufficient for gold plating or is there a different transformer(voltage and current requirement)Thank you for your time and answers--Phil
LinkBack URL
About LinkBacks
