Amps if you're tank plating. Volts if you're brush plating.
Hi, Just starting out and have been doing quite a bit of research for hobby plating but can't seem to get a definite answer on power supply. I have a power supply that I can adjust the voltage with but not the amps, do I NEED to control both? Some say calculate for volts and the amps will follow (ohms law), yet some say x number of amps are required so adjust the volts to suit. Regardless of the actual amount of volts or amps which one is it? Thanks in advance.
Lance Caswell
Short answer: NO.
Long answer: fact is, you CAN'T control both. You chose which one to control, and the other will follow. So in this respect, you ARE controlling both: directly controlling one, which indirectly dictates the other.
Which one you chose to control depends on your power supply capability, and/or which method (voltage or current control) you elect to use.
Sean
Seans Zinc Plating page
