Connect with Facebook
Closed Thread
Old 03-21-2002, 10:49 AM
hparent
Default Silver on copper
I am new to electroplating, and would like some guidance on what is required to add silver plating to copper. The copper transmission line at our FM transmitter site is made up of concentric copper pipes (Inside pipe about 3/4" dia., outside pipe about 3" diameter). The inner pipe sections are connected together using silver plated 'bullets' that fit on the inside of the pipe. There is a considerable temperature rise due to poor electrical contact between the silver plating of the bullet and copper pipe that I think would be improved if the inside of the pipe where the bullet fits were silver plated. I have various DC power supplies available, and a piece of pure silver 4"X1"X0.1" in size. Is the Silver Plating solution all that I need to plate the inside of the ends of the copper pipe?
Old 03-22-2002, 01:02 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Silver on copper
Silver should go right onto copper no problem. Get some silver solution, and use your piece of silver as a plating wand (not even required, you can use a stainless steel wand and the silver will plate from the solution, but will make the solution last much longer)
Clean you pipe very well, connect the power and plate away.
Have A Web Site?
Old 03-23-2002, 10:40 AM
hparent
Thanks for your response. I have ordered 4 oz. of the silver plating solution from your rep (Jim McMillen)in Port Perry.
hp
Closed Thread
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
copper over silver Kurt Electroplating Questions 3 07-18-2006 01:27 PM
Polishing Silver, Gold, Copper fjkratky Metal Polishing Questions 0 05-23-2004 10:45 PM
Strike copper or bright copper after zincate? mdarr Electroplating Questions 2 06-29-2003 03:23 PM
Silver Plating on Copper hparent Electroplating Questions 1 04-03-2002 06:16 PM
