Results 1 to 5 of 5
Thread: Surface area question
  1. #1
    carts69 is offline Amateur Metal Finisher
    Join Date
    Nov 2007
    Posts
    54
    Default Surface area question
    Please can anyone advise on the correct amps for nickel plating a zincated strip of aluminium size: 38cm long, 4cm wide, 3mm thick. Never found it easy to work our surface areas so any advice would be great as the piece is awaiting a bright nickel finish!
    Thanks in advance.....
  2. #2
    stealthbob is offline Newbie
    Join Date
    Jun 2010
    Posts
    16
    Default Re: Surface area question
    38x4x2=304 cm2/119.7 Square Inch/10 Square feet
    The edges of 3mm are typically negligible but in this case add 25.2 cm2/9.8 Square inch/.82 Square feet
    Totals 329 cm2 /129.5 Square Inch/10.79 Square feet
    "Success is the ability to go from one failure to another without loss of enthusiasm"
    Sir Winston Churchill
  3. #3
    lcaswell's Avatar
    lcaswell is offline Caswell Inc President
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    643
    I don't believe that calc is correct. You have the sq cm correct, but your conversion to sq inches is wrong.
    Convert to inches, then use this tool - Caswell Inc - Calculating Surface Areas
    Makes life a lot easier.
    38cm = 15 inches
    4cm = 1.5 inches
    3mm = .12 inches
    So, 15 x 1.5 x 2 = 45 sq in
    plus
    1.5 x .12 x 2 = 0.36 sq in
    plus
    15 x .12 x 2 = 3.6 sq in
    Total = 48.96 sq inches
    Nickel needs .07 amps/sq in, so use approx 3.4 amps
    Lance Caswell
  4. #4
    Join Date
    Jun 2010
    Posts
    16
    OMG..sorry.
    Yeash it sucks when your kids take over your account and post eh
    Brain fart...I was not paying attention when I did that.
    Thanks for stepping in to make sure it was right....
  5. #5
    Join Date
    Nov 2007
    Posts
    54
    Thanks for both your input, looks like 3.4 amps is the way forward, cheers again!
Thread Information
Users Browsing this Thread
  1. Surface Area
    By Raadio in forum Anodizing Questions
    Last Post: 01-08-2010, 01:03 AM
  2. Surface area question
    By carts69 in forum Electroplating Questions
    Last Post: 11-28-2007, 08:58 AM
  3. Surface area question
    Last Post: 11-19-2007, 01:44 PM
  4. surface area?
    By chromebanshee in forum Electroplating Questions
    Last Post: 05-09-2006, 11:23 PM
  5. surface area
    By txturbo in forum Electroplating Questions
    Last Post: 06-05-2003, 02:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
