Once you have the part polished out you have to make sure that it is clean. This is where the water break test is done. If the part passes, then you would immerse in the Deox for 7 to 8 minutes, rinse and go into the zincate. When removed from the zincate, just shake off the excess and go immediately into the electroless bath. Adhesion issues arise from the part not being thoroughly clean.
LinkBack URL
About LinkBacks
