Old 10-14-2003, 11:10 AM
geeteex
Default nickel anodes
I have to nickel and chrome plate 12 pieces of 1-1/2" square tubing 33" long. I'm going to use a piece of 4" pvc pipe for my tank. My question is, do I need my anodes to run the lenth of the tubing on both sides of the tank? Where can I get Nickel anodes that length?
Old 10-14-2003, 08:48 PM
mcaswell's Avatar
Caswell Inc Founder
See the manual and read the Woronko Plating Chamber instructions.
You can then use just two anodes placed at the top of the 33" tube.
The tube is used vertically, with a sealed endcap at the bottom.
The part is then plated 8" at a time, lowering it after the plating time for the respective thickness.
Have A Web Site?
Old 10-21-2003, 05:14 PM
geeteex
Default anodes
I would like to shorten the time it takes to plate using the Woronko tank. Would there be a problem with taking two 8" anodes overlapping them about 1/4 inch and riveting them together with stainless rivets to make the anode about 16" long? Also, would it matter if I started with the tube completely emersed in the tank and raised it as it was plated?
Thanks, RICH
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 04:03 AM
Copper Contamination in Nickel Solution mswall Electroplating Questions 3 02-27-2005 12:53 PM
electroless nickel vs regular nickel Rocky Electroplating Questions 1 07-24-2003 03:12 PM
I think I ruined my nickel bath Tad Anderson Electroplating Questions 1 05-24-2003 11:28 PM
Chrome, Nickel or copy chrome? dwthomas Electroplating Questions 1 02-15-2003 02:49 PM
