Connect with Facebook
Closed Thread
Old 03-25-2002, 02:13 AM
Kurt
Default copper over silver
I have a small metal trumpet tube that is brass with silver plating. The silver plating is about 50% worn off and has some pitting. What I want to do is plate over the piece with copper, without removing all the silver, and then final plate with silver.
Can copper go over silver?
Also, what is the difference between the silver in 4 oz bottle and the larger bottle that is cyanide free?
Old 03-25-2002, 09:09 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: copper over silver
Yes, but an easier solution would be to buff the tube until the silver has been removed and also the pits, then re-silver it.
All our silver solutions are cyanide free.
You could also use our SilverSmith/Plater product for this application.
Have A Web Site?
Old 07-18-2006, 11:07 AM
roelani is on a distinguished road
Hi! I have the same problem as the original poster but my project would be to resilver plate an antique flute which I think is made of nickel, then silverplated. It's the silver plate that seems to be affected by the pitting and wear, and the nickel is popping through.
Should I also sand it smooth to remove the leftover silver then resilver right on top?
-k-
Old 07-18-2006, 01:27 PM
lcaswell's Avatar
Caswell Inc President
-k-
Sand it smooth to remove the pits, which will also remove the silver. Then use Silversmith/Silverplater to replate.
Lance Caswell
Have A Web Site?
Closed Thread
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
Polishing Silver, Gold, Copper fjkratky Metal Polishing Questions 0 05-23-2004 10:45 PM
Strike copper or bright copper after zincate? mdarr Electroplating Questions 2 06-29-2003 03:23 PM
Silver Plating on Copper hparent Electroplating Questions 1 04-03-2002 06:16 PM
Silver on copper hparent Electroplating Questions 2 03-23-2002 10:40 AM
