Old 10-23-2003, 04:36 PM
mdarr
Default Silvaspray on a primered surface
I posted a question awhile back but never got an answer to a problem I had in using Silvaspray. I primered a fiberglass fuel door on a car and then applied the Silvaspray as instructed. After letting it cure for three or four hours, I placed it in the copper bath. When I pulled it out, the copper had plated to the Silvaspray surface but the Silvaspray itself lifted from the primered surface. can you not use Silvaspray over a standard primered surface??
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Sand blasting media to use for surface prep tavo1765 Powder Coating Questions 13 03-18-2005 11:58 PM
Anodizing without knowing surface area? sbpoole Anodizing Questions 3 01-06-2005 07:09 PM
pimpling surface, please help chrisk Metal Polishing Questions 3 05-22-2004 12:13 AM
SILVASPRAY.....PROBLEM WITH BLISTERING! mdarr Electroplating Questions 2 03-28-2004 09:42 PM
