We had one in development, but couldn't get a consistent finish.
We don't currently have any plans to release black nickel.
Ok. A couple of related questions, then
1 - What exactly is the difference, if any, between black nickel and black chrome? 2 - If I nickel plated and then used a blackening agent, would it be possible to achive a reasonable approximation of black nickel plate? |
The difference is the same between regular nickel and chrome. They're two different metals with different properties.
Yes, you could experiment with the blackeners, but take note that the blackeners are meant to produce an antiqued like black finish, whereas the black nickel is supposed to be shiny with a black lustre.
Need Support? Check out <a href="http://www.caswellplating.com/support.htm" target="_blank">our web based support system.</a> |
| After 1500g sanding, and black emery, frame has black streak | fizlfry | Metal Polishing Questions | 8 | 04-26-2005 11:09 AM |
| Caswell burner black? | mtnbiker | Powder Coating Questions | 1 | 04-13-2005 01:15 PM |
| Nickle "Plug-N-Plate" question HELP!! | pyro1711 | Electroplating Questions | 1 | 08-03-2004 10:29 PM |
| Black Dye problems/Smears and Streaks | Easttex | Anodizing Questions | 1 | 07-16-2004 10:43 AM |
| White Compound Turns Black? | GrillMan | Other Metal Finishing Questions | 2 | 08-23-2003 03:12 AM |
