Old 10-30-2003, 09:33 PM
93BlackFD
Default Nickle Plating Disc Rotors
Can you nickle plate disc brake rotors at home? will it stand up to the weather? Does it die the metal or rub off w/ brake application?
i'm tired of mine rusting
Old 10-31-2003, 08:53 AM
Tim Wiltse
The plate will turn to dust the second the pads hit it.
Later,
Tim
Old 11-22-2003, 08:54 PM
red911's Avatar
red911
Understanding that where the brake pads contact the rotors, you will keep raw steel, are you interested in just plating the "hat" and the area that the pads don't contact?
Then, the plating would hold.
Old 12-22-2003, 05:52 PM
BryanD
How do you plate one part of the rotor but not the contact part?
Old 12-22-2003, 06:21 PM
red911's Avatar
red911
You plate the entire rotor and the pads will quickly rub off the plating. In this way, you are protecting the majority of the rotor.
Old 12-22-2003, 11:06 PM
Moderator
bhhodges is on a distinguished road
why bother plating an intire rotor when part will be rubbed off the the brake pad anyway.
Old 12-23-2003, 01:46 PM
BryanD
It doesn't really matter to me. If I can plate the entire rotor and the parts that aren't in contact with the pads hold up, great. If I can only plate the parts that that aren't in contact, that great too. I'm not expecting the plate to remain on the parts that are "grapped" by the pads, but I don't want the rubbing to cause the rest of the plate to peel or flake off.
Whichever way works the easiest is great! Thanks for you help!
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 09:11 AM
plating M/C brake rotors snortn850 Electroplating Questions 2 02-04-2005 11:53 PM
Nickel bath inexplicably quits plating jackf Electroplating Questions 5 01-25-2005 09:55 PM
nickle plating over engraving/etching,advise needed rbent Electroplating Questions 1 12-20-2003 10:53 AM
plating and size power? chromo Electroplating Questions 7 01-18-2003 02:52 AM
