If I use a metal polish with silicone protectants as the last polishing stage prior to Plug N Plate Copy Chroming will it have any effect on the plating process and if so, would cleaning the polished part with laquer thinner be the appropriate last step before plating?
Scott |
Yes, it would probably prevent the plate from adhering to the part.
Lacquer thinner/degreaser should remove the layer. You should always degrease before plating to ensure that there are no traces of oil, especially things like fingerprints.
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Metal Polishing Questions for Nickel Plating | pelletman | Metal Polishing Questions | 3 | 07-31-2004 03:09 AM |
| plug and plating steel rings? | notjustone | Electroplating Questions | 0 | 12-05-2003 05:11 AM |
| Polishing, Chrome Plating and Powder Coating | REVS | Services Offered/Wanted | 0 | 04-19-2003 06:35 PM |
