I think the material is loose corrosion products.
Anyhow, I filter my electrolyte bath in my 1.5 gallon tanks (pails) after every weekend session.
I took a plastic yogurt container and drilled many 1/4 inch holes in the bottom and side up about 1 inch.
I then put a paper coffee filter in the bottom of the yogurt container, dampen it so it sticks and pour my electrolyte through it, into a funnel, then into an old DI water container.
I hope this helps. Keep everything clean!
Team FASTLIKEJUDY
LinkBack URL
About LinkBacks
