Results 1 to 1 of 1
Thread: Copy Cad Dull Discolored Finish
  1. #1
    RMW
    RMW is offline New User
    Join Date
    Feb 2011
    Posts
    1
    Default Copy Cad Dull Discolored Finish
    Bought Copy Cad 5gallon setup. Probably plated less than 15 times with it. It is new solution. My first practice pieces on 5" copper pipe came out good. So did the 2-3 steel motorcycle pieces after that (largest steel pieces I have done) over 100sq.in. After that all the pieces (10sq.in or less) I have done come out blotchy, uneven and slightly discolored. Like a very light brown. Been following Caswell instructions.
    100-110' Zinc Bath Agitated
    160-180 SP Degreaser
    Using .14amps/sq.in.
    Have 25amp rectifier from Caswell, using digital multimeter to measure current to set calculated plating amps needed.
    Looking for bright zinc finish.
    Noticed where the wire hanger runs near and on some edges of the part there seems to be less or no discoloration.
    Discoloration isn't as noticeable in pictures, so I have one pictures shows piece next to store bought bolt
    Couple pictures:
    http://www.rohrmotorworks.com/2012-0...M156%20004.JPG
    http://www.rohrmotorworks.com/2012-0...M156%20008.JPG
    http://www.rohrmotorworks.com/2012-0...M156%20009.JPG
    Appreciate any help and suggestions.
    Thanks
Thread Information
Users Browsing this Thread
  1. How do i get a dull finish?
    By Ekimusman2 in forum Electroplating Questions
    Last Post: 01-21-2012, 10:36 AM
  2. Dull finish
    By Weld-it in forum Powder Coating Questions
    Last Post: 11-03-2011, 12:22 AM
  3. New to Copy Cad, dull finish
    By jonbarrett in forum Electroplating Questions
    Last Post: 09-06-2008, 10:11 AM
  4. Dull Finish
    By fredmc in forum Powder Coating Questions
    Last Post: 11-17-2007, 07:34 PM
  5. Copy Cad Plating - Keep getting dull finish
    By dmcclain in forum Electroplating Questions
    Last Post: 04-18-2005, 11:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
