+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: Copy Chrome Questions
  1. #1
    Default Copy Chrome Questions
    I am interested in the Copy Chrome system for starters, i'm not sure if I want to jump right in with the real chrome system. My question to the forum: would the Copy Chrome be OK to use on medium to small motorcycle parts and will the durability and looks be suitable and what type of care is needed, wax etc.
    Junodale
    Share with Facebook
  2. #2
    hello Junodale,
    I'm new as well, would greatly appreciate any feedback you may have received. Sounds like we have a lot of the same questions.
    chad.williams@vygorsolutions.com
    Good luck!
    Chad
    Share with Facebook
  3. #3
    Join Date
    Apr 2003
    Posts
    52
    For my personal use, copy chrome does everything I'd want as far as finish and durability. However, it's not chrome.
    Copy chrome will need to be polished from time to time to keep it's mirror finish, chrome doesn't.
    Though copy chrome gives you just about the same chemical durability and rust resistance as Chrome, it isn't near as hard. Copy chrome is much more sucseptible to physical abrasions, such as scratches and weather erosion than true chrome.
    I don't do chrome plating and the few times I get a request for it (rarely since I do mostly jewelry and personal items), I just explain the differences between copy chrome and real chrome, I show them what a good copy chrome finish looks like and then tell them how much having that one ciggarrett lighter or eyeglass frame Chrome plated will cost at the local chrome shop. Most are perfectly happy with the copy chrome.
    Share with Facebook
  4. #4
    Default attn: caswell. is this a good description of copy chrome
    Quote Originally Posted by tbloss001
    Share with Facebook
  5. #5
    tbloss001 i am also interested in copychrome process. was considering doing smaller auto & bike parts with it. is abrasion durability that much of a liability in your opinion? by needin polished to keep its mirror finish, do you mean it clouds? thanks. mike
    Share with Facebook
  6. #6
    Join Date
    Apr 2003
    Posts
    52
    copy chrome, just like regular nickel, will dull over time.
    A couple of wipes with a polishing cloth will bring back the luster, but with a true chrome plating, it won't dull or oxidize at all.
    Share with Facebook
  7. #7
    Default chrome over
    I was wondering if you could chrome over copy chrome and if so why would you then want to use copper first? I ordered the copy Chrome kit and had intended to do small car parts such as brackets, hings and pulley parts. But after hereing some of the feed back, if it were to tarish and fade maybe this would not be best and was thinking that maybe I could get a chrome kit and chrome over it. Any thoughts?
    thks
    Share with Facebook
  8. #8
    Join Date
    Apr 2003
    Posts
    52
    I suppose you could chrome over copy chrome, but why would you want to? Chrome is what imparts the hard, bright white/bluish finish we all know and love. Copy chrome is just a fair imitation in certain instances.
    The copper part of the triple chrome system is a VERY important part.
    You need that copper for coverage, adherance, and ease of finish. Copper is a heck of a lot easier to build up and polish to a high luster than nickel. If your copper finish isn't good, then your nickel finish won't be good and if your nickel finish isn't good, then your chrome, etc, etc etc...
    Share with Facebook
  9. #9
    would a finish such as zoopseal be an answer to the dulling of copychrome?
    Share with Facebook
  10. #10
    Default more dumb questions
    if copper is a very important part of triple chroming how can "Copy Chrome" get away without using it. Would it be possible to get a picture of your copy chrome setup? and if possible a quick break down. I'm just trying to figure out how to set it up in garage. Any tips you have would be great. Thanks in advance.
    Daryl
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. triple chrome vs. nickel/chrome vs. copy chrome
    By spectraflamed in forum Electroplating Questions
    Last Post: 01-21-2007, 10:07 AM
  2. copy chrome vs triple chrome plating
    By splbnd27 in forum Electroplating Questions
    Last Post: 06-21-2006, 07:35 AM
  3. Differet copper plating questions, plus copy chrome/ nickel?
    By krsimulis in forum Electroplating Questions
    Last Post: 07-26-2004, 12:25 AM
  4. Copy Chrome Start-up
    By Elitefisherman in forum Electroplating Questions
    Last Post: 04-18-2004, 04:24 AM
  5. Copy Chrome Immersion system questions.
    By Great_Scott in forum Electroplating Questions
    Last Post: 03-20-2002, 05:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
