Old 04-04-2002, 11:02 PM
spectraflamed
Default a bunch of questions
Sorry for all the questions here it goes:
After I polish and before I go to plate I know I need to clean the metal from all the polshing compound and other junk that may be on it, is the cleaner you list in your kits the step that does this?
Will a piece of copy chrome tarnish at a much slower rate than just a piece of buffed/polished metal?
Will applying a clearcoat like the por stuff help eliminate or slow down tarnishing on a plated piece? and/or a buffed/polished piece?
If candy (transparent) painting over parts of the chrome surface is nickel or zinc plating just as effective in terms of shine and resistance to tarnish?
What happens if you plate something that has plastic as part of it? Will the plastic come out just fine or change color, melt etc..?
If I polish a piece of metal using your polish products and then clean with a degreaser or laquer thinner and paint right away will the paint keep the metal from tarnishing? would plating the piece first help reduce the chance of tarnishing?
I know plating plastic is tricky but just how hard is it? After plating metals for a few months with one of your kits and getting a feel for how it works would plating plastic be possible?
What plate do you recommend for items that will not be in heavy use (indoors and not handled much) but need to resist tarnishing (due to being displayed)?
With your kits is everything included or do you need a power source or anything else? What do you use the put the parts into the plating solution?
Is it difficult to store the plating materials when not using them? Do you have to clean up everything everytime or can you set up the system and use it as needed?
Many thanks for the help I look forward toplacing an order SOON!!
Old 04-04-2002, 11:53 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: a bunch of questions
Yes
Yes
Yes
No, chrome(with a nickel base) is more resistant.
Plastic will not be plated, unless you want it plated, then you'll have to cover in conductive powder. Won't melt unless using electroless system, which has high temp liquids.
Naturally
Really depends on the specific application, but generally yes.
Yes. Compare plating to spray painting a car. Would you spray paint you car? Probably not. Would you after practicing on old cars for a few months? More likely.
What finish do you want? What are the parts? Gold, silver, nickel?
Power source generally isn't included. You also need some small stuff like copper wire, piece of copper pipe etc. You suspend the part into the solution from a copper bar over the tank, by a piece of copper wire.
You can easily store indefinately. Just put the lid back on and put on a shelf.
I would recommend getting our plating manual before ordering. It will give you some insight about what's involved, without a large expense on your part. It's $25, and is refunded when you buy a kit that includes the manual as part of the price.
Have A Web Site?
Some newbie questions... kiwijetpilot Anodizing Questions 16 03-12-2005 08:18 PM
A few newbe questions thestormfamily Electroplating Questions 4 06-30-2004 08:54 AM
Couple of questions... Bobby-S Electroplating Questions 1 06-13-2004 04:34 PM
A couple carb plating questions KenL Plating Pot Metal 0 01-23-2004 08:34 PM
more newbie questions linnracing Powder Coating Questions 7 01-16-2004 06:40 PM
