If I must activate it first, I cannot use any acid on the part. So, to get away with not using any acid, is there a non-acid activator, or can I pre-plate the part (via brush plating) with something that does not need activation, such as copper or silver, THEN brush plate the gold over that? thanks for any help. |
I had to do this on the 1956 Motorola transistor radio I re-plated in gold. The substrate was old nickel plate under peeled brass laquer. I took it all down with Mother's Mag & Aluminum polish, till it was perfectly shiney, then followed with solvent to make sure it was perfectly clean. Followed with Gold Plug 'n Plate.
Hope this helps- Chris |
I have obtained excellent results gold plating directly over nickel without any activation. BUT it has to be clean and free of oxides, and as polished as you desire the final gold to be. You won't be able to polish the gold much at all without going right through it.
For fear of wearing through nickel plate, use a metal polish as suggested by tbloss. Or you can use Flitz polish from Caswell, which will leave a rich glossy surface as well. Clean well because ANY metal polish will leave a thin film of wax as a sealant. This must be removed by solvent dipping and agitation thoroughly before attempting gold plate! If you go through the nickel in the polishing process, you can re-nickel with a brush plate as a touch up. But beware. In this case you will HAVE to use an acid pickle to activate the old nickel in the area you are touching up. When done with the gold, it helps to apply a thin coat of lacquer seal to protect it. Ken |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 10:11 AM |
| How to plate Nickel over old Nickel when steel shows through | ASHENASH | Electroplating Questions | 3 | 04-22-2005 04:03 AM |
| gold PCB edge contact plating | fargap | Electroplating Questions | 2 | 07-27-2004 08:24 PM |
| Plug n Plate Gold over Sterling | novenarosary | Electroplating Questions | 0 | 03-12-2004 11:00 PM |
| Plug n Plate | lphurley | Electroplating Questions | 3 | 09-23-2003 01:15 AM |
