I have an old carbon steel putter that I am thinking about either nickel or copper plated. It currently has a nickel-plated finish that is in bad shape. How Should I go about removing the prior finish to get down to the original metal? Would the process the same for either plating I would use? Thansk in advance for your expertise and info.
Removing nickel plate is fairly straightforward. Our manual has a formula for a chemical stripper that uses household acid.
You can also sand blast, grind or sand the finish off.
I heard that Acetic Acid (vinegar?) or Muriatic Acid (Hydrochloric Acid) will work to remove finishes. Where do you get these chemicals and what concentrations do you need? Thanks!
================== Quote:
***************** Many of life's failures are people who did not realize how close they were to success when they gave up. - Thomas Alva Edison |
Seriously, the pickel we recommend is muriatic acid based, commonly known as concrete cleaner and available at a hardware store.
The pickle won't remove any of the brass.
It's like stripping paint. Paint stripper will remove the paint, but won't touch the base metal.
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 09:55 PM |
| Removing copper plating.......Help! | Coltsaa | Electroplating Questions | 8 | 11-03-2004 11:34 PM |
| boron plating on electroplated Nickel | jackf | Electroplating Questions | 0 | 03-29-2004 01:41 AM |
| removing nickel plating from brass? | thomaconda | Other Metal Finishing Questions | 2 | 02-27-2003 09:36 AM |
