Results 1 to 2 of 2
Thread: Copper plating non-conductive material
  1. #1
    Hockeydemon is offline New User
    Join Date
    Jun 2013
    Posts
    2
    Default Copper plating non-conductive material
    This will be my first go at electroplating, and I am aware that plating to a non-conductive material is not easy. That being said one of my majors (undergrad) is biochemistry, and I took a class on electrochemistry awhile back. Not that it's overly relevant, but I do have a decent theoretical understanding of what's going on.
    I would like to copper plateicon some sand dollars I picked up at the ocean. I would also like to buy the least amount of things possible - I'm a poor college student. I have a large car battery charger that runs 12v/10amp,40amp & 100amp charges (It is possible the 10amp runs at 6v but I need to check). The total surface area of the sand dollar is ~14-20sq".
    I was going to seal the sand dollar in "Rust-Oleum Specialty 11 oz. Specialty Lacquer Spray Paint" from home depot. It is highly resistant to acid, and should provide a nice protective coat (suggestions?). I was going to make the sand dollar conductive by picking up some PCB (circuit board) graphite paint (or silver?) from radioshack. I was going to comprise my electrolyte solution using this stoichiometric ratio: 1.25 CuSO4· 5 H2O + .467 H2SO4 (200g,90mL,25mL) - diluted with DI water to 1L. I was going to use copper piping for the anode - would you suggest a bath in sulfuric acid in order to clean up possible impurities? I was going to use stump removed for my source of copper(II) sulfate - should I make an attempt to purify this before hand or would using a 'dummy cathode' initially suffice?
    Assuming all of that sounds reasonable.. I need to figure out how many/what kind of bulb systemicon I should have - if one is even needed. Suggestions would be much appreciated.
    I'll gladly provide any additional information that I might have left out.
    Thanks in advanced.
  2. #2
    Join Date
    Jun 2013
    Posts
    2
    Default Re: Copper plating non-conductive material
    I've been looking around at a way to make the non-conductive material conductive, and I might have found a way to chemically deposit silver ions onto most any material. If I dissolve silver bullion in nitric acid to form silver nitrate. I can then make a 'silvering solution' by combining silver nitrate, house hold ammonia, sugar, and sodium hydroxide. Once the solution is prepared if you heat it to a near boil, while the material is in it the Ag+ ions deposit onto anything that they can. It gives a pretty cool mirror on anything that it happens to come in contact with.
    That being said I was considering seeing how resistant my lacquer is to dilute hydroxide. If it can with stand it then I will probably go this route because 1 silver bullion is ~$30, and can silver quite a bit of material.
    I still am unsure of my power source though. Electricity is not my forte - though I've been doing my best to learn about resistors, transformers, conductors ect.. If my car charger runs at 12V 2amp trickle charge how do I drop the voltage down?
Thread Information
Users Browsing this Thread
  1. Copper Conductive Paint
    By spartin in forum Electroplating Questions
    Last Post: 12-08-2011, 10:02 AM
  2. need plating over caswell copper conductive paint
    By pgronqui in forum Services Offered/Wanted
    Last Post: 08-30-2011, 11:49 PM
  3. Problems with Copper Conductive paint
    By d94pam in forum Electroplating Questions
    Last Post: 12-17-2009, 09:00 AM
  4. Conductive Copper or Silvaspray
    By kssmybass in forum Electroplating Questions
    Last Post: 11-29-2007, 09:17 AM
  5. conductive of plastic after copper conductive paint
    By bobboss351 in forum Electroplating Questions
    Last Post: 11-19-2007, 01:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
