Hi,
I restore antique radios and telephones. Most of my parts are small such as brass screws and rings etc. I have tried to use those "Texas Platers" brush things, but have had very little luck. They put the Nickel on so thin, that when you buff out an item such as a knurled nut, the brass peeks out from under the nickel. Your one gallon kit, will it put a heavier coat on so you can buff it, or will it leave the part shiney when it comes out (which would be even better)? Polishing the brass to a high shine is not a problem before plating. Darryl |
The longer you plate the part, the thicker the plate becomes. So you leave it in until the desired thickness is reached.
If you polish prior to plating, the parts should come up shiney. A quick buff will probably be required.
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 10:11 AM |
| Just a few questions about Nickel plating | dgaspin | Electroplating Questions | 6 | 04-29-2005 08:28 PM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 10:55 PM |
| Differet copper plating questions, plus copy chrome/ nickel? | krsimulis | Electroplating Questions | 1 | 07-26-2004 01:25 AM |
| boron plating on electroplated Nickel | jackf | Electroplating Questions | 0 | 03-29-2004 02:41 AM |
