i have a quart of the same gold but i havent used it but one time on a single item. your going to get much better long term results by using a gold anode instead of the stainless steel. my guess is that you could of used up the gold content by not using a gold anode.
bill |
The Tank plating gold from Caswell is somewhat finnicky. If the temperature is off (either way) more than a few degrees from 140 it will misbehave. I did get good results with it as long as the temperature was carefully maintained. However, it went flat after a few articles for me, too. I was using a gold anode. I don't think it dissolves the gold, but I agree you're better off with a gold anode rather than risking the introduction of even trace amounts of nickel, iron, etc. into the alkaline solution by using a stainless anode.
I have found that the FastGold is fabulous, much easier to use, and longer lasting. Ah, more expensive, too! But--you get what you pay for. Ken |
the fast gold is by far my choice to gold plate with , it dosent sound like much to work with in a 4 oz. bottle but trust me it goes farther than you realize i have plated several hundred small items out of one tiny bottle just be care of any spillage or excess dripping.
bill |
I had the same problem, where the solution works great at first, then nada later, even though I used "virgin solution" on both days.
I found some techniques that might help. Do your best to keep the solution clean. Use a gold anode helps, but the integrity of the solution is important. After getting your "first pristine results", change the solution, even though it's still clean. Plate again. Change the solution often. Reheat the solution as little as possible. Find ways of keeping it warm on a steady basis. The more you heat it, the more you are compromising. Make sure to use good safety even though the solutions are cyanide free. Add a surge protector to your rectifier for added security if you are comfortable with that. If not, plate safely. |
| gold plating on brass | jomida | Electroplating Questions | 6 | 03-28-2009 07:41 PM |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 10:11 AM |
| Question about gold plating a gun | arny068 | Electroplating Questions | 1 | 03-26-2005 01:18 PM |
| Question on gold plating brass. | oldtoys1961 | Electroplating Questions | 2 | 12-29-2003 05:45 PM |
| Gold Plating Question | Rusty Armstrong | Electroplating Questions | 2 | 03-21-2002 08:12 PM |
