+ Reply to Thread
Results 1 to 7 of 7
Thread: titanium
  1. #1
    Default titanium
    Can titaniium be plated? Would the EN process work?
    Share with Facebook
  2. #2
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    no it cant be plated in its natural state, i supposed you could make it conductive but i dont see the point of going to that extent. what are you trying to do with it??all i use it for is hangers for my anodes.
    bill
    Share with Facebook
  3. #3
    Default titanium
    I want to try to use the EN process(not really a plating process I dont guess)to put a surface on a titanium bolt that will be used in a titanium bike frame. I want to do this to keep from having a cold weld form on the two close-tolerance parts
    Share with Facebook
  4. #4
    Join Date
    Apr 2003
    Posts
    52
    In that case, why not just use a zink washer?
    If you're worried about the threads, use a little teflon tape.
    Share with Facebook
  5. #5
    Join Date
    Apr 2003
    Posts
    52
    One other thing.
    Though Ti has problems plating, it can be very easily anodized.
    Anodising it may solve your worries.
    Share with Facebook
  6. #6
    Ahhh OK.. I didnt know it could be anodized. It is the threads as well as a smooth shoulder just below the head that Im concerned about.
    Anodizing may be the way I go on it.. Going to experiment a bit wiht different processes/coatings. It would have to be somewhat unnoticeable on the finished product.
    Share with Facebook
  7. #7
    Join Date
    Apr 2003
    Posts
    52
    You can always mask off the head so the portion that can be seen won't be anodized. As for the threads, you may want to be carefull with voltages and bath times so you don't fall out of tolerance.
    check out this link for an easy setup.
    http://www.valhallaarms.com/wyvern/t.../anodizing.htm
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. titanium motorcycle exhaust muffler?
    By mtnbiker in forum Powder Coating Questions
    Last Post: 04-26-2005, 09:01 AM
  2. Titanium Anodizing
    By ron423 in forum Anodizing Questions
    Last Post: 08-23-2004, 04:09 PM
  3. Use of Titanium.
    By usao in forum Anodizing Questions
    Last Post: 05-17-2004, 10:28 PM
  4. Titanium anodizing
    By lorenzo in forum Other Metal Finishing Questions
    Last Post: 06-27-2003, 08:56 AM
  5. titanium
    By dburke26 in forum Electroplating Questions
    Last Post: 04-20-2002, 01:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
